Search in proper geometrical set by name VBA 1
Smileyoer
16
I have a problem which I can not find a solution for. So I have several geometrical sets with different names. Example: GS1, GS2...
In these geometrical sets I have points, lines, planes inside them, but they have the total same name in each geometrical set.
Example: GS1: point, line, planeoffset
GS2: point, line, planeoffset
My problem is that with the search function, I can find all of the point by their name, but especially I only want to select the only one which is in the GS2.
Reference to item it's not an option, buts it's another problem! :D
Thank you for your help!
Thank you for the answer Ferdo.
Maybe I am wrong, but it is possible to select example the planeoffset in the GS2 without deselecting the geometrical set?
How is it possible for multiple search, I mean search in the XY named geometrical set and then select the XY point from that geometrical set? It is not clear for me.
Ohh I tried your code Ferdo thanks for your useful answer! :)
