Hello All,
If I open an assembly and make one of the pieces the work part. Then I try to create a section cut of the part using the z-plane as my cut plane. I then make the assembly my displayed part. If I make that same piece the displayed part it realigns the section cut to the current z-plane of the piece part. And when I go back to the assembly it is incorrect. I then have to open the section cut and click ok (without changing anything) and it updates and is correct. It seems that the section cut automatically switches to use what ever z-plane is currectly active, rather than being associated to the z-plane in which it was created.
Any thoughts on a fix?
UG NX3/NX4/NX6
Vericut 5/6/7
AutoCAD LT
UG NX3/NX4/NX6
Vericut 5/6/7
AutoCAD LT
