Section Lines Appearing In My Extrusions
BrittToolEngineer
Aerospace
Aug 4, 2016
239
Greetings:
I have a new file where I am extruding components, and there are section line geometry that you can see. This just started, not sure if I have a setting that changed, but wanting to know if these can be hidden?
Brent
Which version of NX are you using?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
Hello Brent,
I guess you are talking about Edit section/Clip section command in "modeling" (if "sections" from assembly navigator is ticked then section lines can be seen in modeling).
Please go to assembly navigator and un-check the "sections".
I hope it helps.
Adkad
NX11
