cowski
- Apr 23, 2000
- 8,202
We recently recieved a drawing file with 2 section views on it (A and B). When you update the drawing views, section A-A is really section C-C; someone fudged the view name by typing in the A-A. When you try to correct the problem by editing the view label a message box pops up that says letter A is already in use. There are only 2 secion views, no other special views (detail, broken, etc).
This is on NX2. Part cleanup does not help. Any ideas what is causing it and how to fix it? It is as if there were 3 section views to start, then deleted section A and now the letter A is not available.
