Section Views displaying wrong objects
Dzine3D
3
I have been having this problem recently with SW2010. When I create a section view it is displaying some objects of the model that are BEHIND the view. It just started doing this recently, and I haven't changed any of the settings, as far as I know. Has anyone had this problem?
As you can see in the attachment, there are gussets on the left and right sides of this structure. When I section it in the middle, with arrows pointing left, it is showing the gussets on the right side, which are behind the section.
If you go to the part/assembly level and section the part do you get the same result?
This would allow you to narrow it down between the drawing or the part/assembly.
Scott Baugh, CSWP [pc2]
Berry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
"If it's not broke, Don't fix it!"
faq731-376
Is there any chance you have a configuration where the gussets are not mated/located correctly? Are the gussets somehow defined as fasteners and being excluded from the section cut?
Joe
SW Office 2008 SP5.0
P4 3.0Ghz 3GB
ATI FireGL X1
SBaugh - It sections correctly at the Model level
JMarv - The gussets are fully mated and located correctly in the model. They are simple extrusions, not fasteners of from the Toolbox.
Ctopher - I can do that for this time, but need to find the problem. I think it lies somewhere in my settings.
Has anyone had a situation where their SW software just started doing weird things and/or crapped out?
Dzine3D ... Are you able to ZIP and post the parts, assy & drawing for testing on other machines?
ctopher - NVIDIA Quadro FX 4800. I've never had other graphics issues, except when dealing with parts in the 100mb range.
