See the link, What kind of failure 8
The crane lost balance, then crashed into the frame.
It looks like the left-most member is well-buckled before the crane ever moves. My guess is they were erecting those members, weren't putting adequate lateral supports as they went. Or maybe just underdesign in the first place.
I notice the guys sliding down the columns. I understand that used to be common in the US (in non-emergency situations) but OSHA made 'em stop doing it that way.
Myo Maung said:
What kind of failure it is?
A catastrophic one.
It appears to be a collapse due to structural instability during erection - it was not adequately braced during the erection sequence. It appears that there is no roof diaphragm bracing (or it failed) which allowed all of the roof beams to buckle sideways.
Possibly, but it looks more to me like the falling steel brought the crane down, not the other way around.
Even if the crane initiated the collapse, the erection bracing was totally inadequate. It looks to me to be an instability failure.
BA
The video starts too late. The buckling of the roof beams has already started, hence the steel erectors fleeing for their lives by sliding down the columns.
The fact the entire roof goes at the seam time implies that all the supports moved in the same direction due to lack of bracing.
But impossible to say without seeing the end view and the actual initiation event.
Looks to me like instability failure. Lateral torsional buckling of the frames.
Agree that without a full sequence you can’t say for sure. Maybe the crane did yank it to start with.
Lateral-Torsional buckling. There should have been more temporary bracing.
Thank you all guys, here is night time and just wake up. Very happy to see all your replies.
I guess these crane are trying to correct back the swayed rafter but it is too late and the damage already there. Some more, this rectification method is still not correct
All make sense to me. This video remind me of the "Big Blue" failure in Milwaukee in 200?.
The amount of exhaust coming out of the crane seems unusual. Either struggling to control the load or maybe some type of engine problem. Not sure though since it's only a brief glimpse. Hope everyone made it through unscathed.
Great sketch! That seems like the likely scenario. But just playing devil's advocate, if the crane had a mechanical issue at the wrong moment, is it possible the load became uncontrollable and instigated the collapse? Not likely but maybe shouldn't be ruled out.
Absolutely. This type of failure usually has multiple "wrongs", either one triggers the other, or occurred simultaneously. The crane must have rated capacity to handle the work, but ... boom, it goes!
Poor old crane. All his fault for failing to catch it. :)
