Seeking assistance regarding MBRs
shootingstars78
9
Hi There
I am designing a plant with MBR. Corect me if I am wrong-my understanding is, the bioreactor does it work, the MBRs advantage is we can put it inside of an activated sludge process, and eliminating additional clarifiers. My additional questions are:
1) Say we are using MBR in a different compartment. For this process does it need any additional aeration?
2) Is only gravity good enough for the feed process?
3) What items to look for when selecting a proper membrane system?
4) How do they allow for working with a higher MLSS concentration? They are just alternatiove to clarifiers, aren't they?
5) Does any one know of any typical operational problems with MBR?
Thanks in advance for all of your time and input, and I look forward to hearing from you. cheers;-)
Your best bet is to contact one of the membrane suppliers as many of the operational issues are dependent upon the type and configuartion of the membrane.
In my opinion, the best product on the market currently is the PURON product of Koch Membrane Systems, Inc.
Sean.
1) Say we are using MBR in a different compartment. For this process does it need any additional aeration? Yes, you need an air sparger below the membranes that helps to clean the membranes
2) Is only gravity good enough for the feed process? Yes, but it depends on your site layout.
3) What items to look for when selecting a proper membrane system? Track record of the supplier.
4) How do they allow for working with a higher MLSS concentration? They are just alternatiove to clarifiers, aren't they? There is a maximum MLSS concentration where the performance deteriorates.
5) Does any one know of any typical operational problems with MBR? No
