RamiHabchi93
- Jan 22, 2017
- 26
Hi
I have an eccentric footing,I need to connect it to a strap footing.and also I need to connect footings with seismic tie beams.
If for e.g seismic tie beams should be designed for axial force=10% column load.
Should I design the strap footing as a column under the 10% axial force and bending moments from eccentric footing at the same time? Or should I connect the eccentric footing to a seismic tie beams and a strap footing.thank u
