I have a discussion with some engineers regarding the selection of the impellers material for horizontal booster pumps that will be used to pump clean water, with the possibility to have small debris passing through the pump (like sand and silt).
The selection is between Cast iron and Bronze impellers, Bronze doesn't rust but cast iron does, BUT at the same time the impeller material must be chosen for both chemical compatibility and wear resistance so we may need to consider one of the duplex metals because most corrosion resistant materials are too soft for the demands of a pump impeller
From your experience with impellers material selection, what would be the best choice for the pump impeller? Is it bronze which is soft or the cast iron which will rust??
We are in the process of finalizing the technical specifications for the required pumps. Your inputs for the disadvantages and advantages of both choices are highly appreciated...
