  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Selection Set 1
ednagc2002
14
Can I create a property from my part with a selection set ? For example if I create a propertie called "Producer" that I can choose between 3 different given names? So that you can´t write nothing there, but select an option.
create a string parameter and in the dialog box select Multiple Values instead of single value before you press "Create Parameter of type"
Eric N.
i don´t have this "multiple Values option"
acctually how do you create this parameter? I did it like shown in the attached photo
hi! I already created this parameter as you told. But where can I found again this created parameter? i acctually wanted in the properties.
Thanks a lot. It works also. How could I call this parameter value that I chose in a macro? ...UserRefProperties.Parameter1 ??
....Parameters.Item("String.10") ??
so if my parameter is called string.10 ? I found this in internet but doesn´t function
