Sensing An Extremely Long Distance With Precision
shearstrength
CA
Anyone could recommend an economical way to sense a steel plate at a distance of 16 feet with precision to 2 decimal places?
I've found Ultrasonic Sensors that can sense the distance, not the precision but costs a fortune.
Any response will be greatly appreciated!
Sorry, misread the specs for this unit! Accuracy still applies
Although, I did verify the "Pacific Laser System". This might actually work well!
Thanks IRstuff!
You may have moved on with this task, but for reference I happened across this manufacturer on another project and remembered this thread.
The second unit from the right has a range of up to 20.7m, and a resolution of 2mm (.08"). Looks like it might need a reflector however.
The unit to the right of it has better resolution and makes no mention of a reflector, but has a range of 3.7m, just a little short of your needs.
No idea about cost but it doesn't LOOK expensive (not that this means anything!)
"Venditori de oleum-vipera non vigere excordis populi"
