Shaft tolerance for bearing
jor1492
106
Hello all,
I have spherical roller bearing bearing with a diameter of 130mm, I want to fabricated a shaft to fit with this bearing. My question is what is a good tolerance range for the fabrication of the shaft?
Thanks in advance
Look it up in the bearing catalogue. There isn't just one fit required, depending on the exact configuration (rotating/stationary housing/shaft etc). I assume 130mm is the OD?
Here's the skf website, with downloads of their catalogues.
Cheers
Greg Locock
