EmilC
- May 2, 2019
- 12
Hi folks,
I'm a structural engineer, specializing in timber and used to designing pretty simple frost-wall foundations up in the tundra of New England. I'm looking to design more haunched-slab or raft-slab foundations at residential scale, both for warmer climates and for shallow-frost-protected and passive-house type foundations. My company does custom houses, so we get into some exciting loads on the foundation from timberframes, Simpson Strong-Walls, steel moment frames, etc.. With frost wall foundations, there's a lot of dead load, member section, and room for rebar to sort that stuff out, but I need to up my game for thin rafts or haunched slabs, especially when they have a thick layer of insulation beneath. I'm looking for key concepts that I should understand, and/or textbooks or references that I should dig into.
For a specific example, say I have a haunched-edge slab on top of say 6" of foam insulation, with soil below, and somewhere along the length of that haunched edge is a big point load, like a column or Simpson Strong-Wall moment reaction. I can look at the haunch as a beam on elastic foundation, but how would I envelope a reasonable subgrade modulus for the foam + soil combination?
Any advice is appreciated!
