Mechaero2006
Aerospace
- Jan 26, 2014
- 29
Dear all,
in the file attached you will see a simple drawing of a part I want to model. The question is about the recommended process to model the boundary conditions and especially the shear flow seen. As stated in the file, everything is known (forces, moments at points 1 and 2), section dimensions and the shear flow values.
What I thought was to put constrains at points 1,2 of my model, insert the shear flow as the load and then check in the solution if the constraint forces and moments match the values given initially. But: How to define the given shear flow in my fea model? Please note that the FEA model created is made of 3D elements (not shells) and the analysis will be linear static (SOL 101 for the MSC NASTRAN users
Other approaches are welcome.
Thank you in advance for your assistance.
![[smile] [smile] [smile]](/data/assets/smilies/smile.gif)
