Shear in concrete T-sections
Alvarobg
22
I have something similar to the following structure:
In order to verify bending ULS, I calculated the effective width of the web, compounded with flange and took its Md and Nd.
My question is: When verifying Shear ULS, do I have to use the same section (flange + effective width) or can I take only the flange + web using only the width of the web?
Thank you!
@rapt: well I am planning to work at least 30 to 35 more years (it was intended as a joke). It takes years or even decades to implement something in Eurocodes, now it’s not even sure if UK will continue to work on Eurocodes. For example Eurocode 8 (EN 1998) is not yet valid in all German states.
Personally I prefer strut and tie methods where my concrete takes only compression stresses and rebar all tension (shear stress is for me only necessary evil).
