LuisUgarte
- Apr 1, 2015
- 23
Hello, everyone.
Just for general knowledge, I would like to know what's the most common practice in your area to transfer column shear loads trough base plates into piers,I know there are three main ways to achieve that and all of the three have something to be concern about.
1.-Shear transfer by friction.
The thing is what about if the grout has not been placed in the right way or even it hadn't been placed. The other situation is about cracks in grout due to forces, which means there wont be any contribution of it.
2.- Shear transfer by anchor rods.
I like this one but I'm concern about the mechanism to be used. As almost of you all know, AISC recommends the use of half of the anchor rods contributing to the resistance, doing that you can ignore the tension forces in anchor rods due to bending, and of course we should make some reductions. The other one is taking into account all of the anchor rods by using washer plates welded to the base plate but this time we have to include tension forces in calculations.
I think the second one could be more expensive and take more time. But the first one could have a displacement before it works, and I'm not sure how can that impact in the base plate behaviour.
3.- Shear key
I haven't used this one, but I've seen a lot of recommendations using this instead of anchor rods, is it difficult to place a base plate with shear key during erection?
What are your thoughts?
Thanks in advance, and I apologize if you see some mistakes but I'm not a native speaker of English.
3.- Shear key
