Greetings,
Short version:
I am somehow messing up sheet/shell surface-to-surface contact (not glued)
Long version:
I am currently using NX Nastran 7.0 and dealing with shell contacts. I made a simple model of 2 shell sheets, .5" shell thickness value, stacked on top of eachother (space between sheets is .5"). I did a simple compression run (sheets in the XY plane, vertical 'up' is +Z) with a small force in the -Z direction. The only way I can get it to run is with glued contacts.
The error I get in the F06 file when using non-glued contact is:
USER FATAL MESSAGE 9143 (SUPER3)
THE SOLUTION FOR THE RESIDUAL STRUCTURE DOES NOT EXIST.
The exact model with glued contact runs fine and gives good results. The only parameter I am setting manually is AUTOSPC=1, everything else is straight default.
I have tried constraining the top shell sheet in to travel only in the Z direction, but this did not help.
A run with 1 sheet and 1 solid works fine with surface-to-surface, non-glue contact.
I knew I was in trouble when I didnt find anything here about the subject (longtime lurker).
Any help on the method or settings I am goofing up would be appreciated.
Thanks,
Dan
Short version:
Long version:
Thanks,
Dan
