We have a single side weld v-groove joint made from 1/4" thick 316L with backing. It's welded in flat position and we require full penetration. We're looking to change the weld process from GTAW to GMAW. For this joint we're sensitive to both chromium carbide as well as oxide discoloration. We are ideally looking to move toward a GMAW pulse spray with .045" wire. My question is regarding the best shielding gas to use. I seem to be getting mixed information regarding the use of 98/2 AR/CO2 versus 98/2 AR/O2.
Some sources say that the use of O2 is better because it gives better arc stability for spray transfer. The absence of CO2 means you're not introducing carbon into your weld pool, thereby reducing risk of carbide precipitation. However, other sources say CO2 give much better penetration. Additionally, with only 2% CO2, the carbon content is low enough that you don't have to worry about carbides and that the use of pulse stabilizes the arc enough so the added benefit of O2 disappears. It seems that each welder and gas supplier has a different opinion. Does anyone here have any thoughts on this?
Further, I was also looking into the addition of N2 into the gas as that's supposed increase penetration. However, I can't seem to find references that recommend a specific percentage. Any input on that would be much appreciated.
Thanks for the help!
