Showing results with transparent mesh
assafwei
Materials
Jul 20, 2008
89
IL
I want to show results (deformation) with one (or all) parts transparent, I need to see what happens inside while still being able to see the whole assembly. Sectioning is not good and in wire frame I can barely see anything. Is there such an option in mechanical?
Scope the result to the body/bodies you would like to see the result displayed for. Then under Result there is a drop down list for Result Display Option select All Bodies.
