CodeRed7
- Jun 5, 2014
- 23
I am currently designing an assembly that requires a sleeve to be shrink fitted onto a potentiometer shaft. I am having issues with analyzing the stresses caused by the fit. I have tried using an online calculator, however no matter what I do I always seem to have stress levels that are too high. I have summarized the information below.
Material
Dimensions
If I need to specify any more information, let me know. Any help would be appreciated, thank you.
Material
Hub Material: 360 Brass Alloy
Shaft Material: 303 Stainless Steel
Dimensions
Shaft Dimensions:
Maximum Shaft Diameter: 0.1248"
Minimum Shaft Diameter: 0.1245"
Length of Shaft: 0.313"
Hub Dimensions:
Maximum Inside Diameter: 0.1244"
Minimum Inside Diameter: 0.1242"
Outside Diameter: 0.25"
Length of Hub: 0.4375"
Fit Specifications:
Type of Fit: Light Drive Fit [FN1]
Maximum Interference: 0.0006"
Minimum Interference: 0.0001"
Engagement Length: 0.1309"
