mistermusso
I need to shrink fit a brass slip ring onto a mica covered shaft.The slip ring is approx 8.00" OD with a bore of 4.25".The shaft has about 1/8" thickness of mica wound onto it.How muck interferance do I need and what sort of temperature should I heat the slip ring to?
