loadangle
- Jan 21, 2013
- 15
I have a Siemens micro-master 440 vfd to control a 7.5 kw,1400 rpm induction motor.now the problem is after running for few days it stops automatically without showing any fault & doesn't accept start command for next few hours or so until i clean it with air.I have replaced the drive two times,but problem remains the same.I have checked the parameters & found them okay. For information i must tell that the drive stays continuous in operation without rest & the room is non ac & bit dusty too.So I personally think that, may be the continuous operation of drive causing some internal component of control card heated & as a result it triggers off command.please ask for details if you want any.thank you.
