nithinv
- Mar 21, 2015
- 26
Hello mates,
I have around 150 NX 2D drafting files which need to be translated into *.dxf format. I used "Dxfdwg" option available in translator. But while opening that dxf file using AutoCAD 2015, drawing is not available under "Model" tab. it appears under "Layout" tab in AutoCAD. But if I export individual file using File>>Export>>AutoCAD DXF/DWG, then it converts the file correctly.
Please suggest which settings I need to change.
Nithin
Tool design - NX 9.0
Nithin
