giacuni
- Oct 14, 2016
- 11
Hello! I am new to ABAQUS and I have trouble to model a simple problem.
I have to model a rail on an elastic foundation with BOEF model: the rail is a beam and is above a series of springs that model the sleepers, ballast,etc.
My model consists in:
- 1 beam of 10 meters (the rail), modeled as a 2D wire
- springs at each 600 mm
- 1 load at the midpoint of the beam
- 2 boundary conditions at the extremity of the beam to fix U1 and U2
I have done the model but it seems that it does not recognize the springs.
I modeled the springs using "connect points to groun (Standard)".
Link
What could be the problem? I attached the cae file. I hope you can see it.
Thank you
Link
Thank you
