Simple Wireless Vibration Monitoring? 1
Luber
3
Most of the condition monitoring systems on the market are highly sophisticated and very expensive. They involve high bandwidth and fast data transfer rates, which are not necessary in my particular application. I need a wireless transmitter/receiver unit that is very simple........only 2 bits of digital data sent when a predefined tolerance limit is exceeded. Any ideas would be helpful.
Please e-mail specs/requirements to dgallagher@ghg.net. Will be happy to provide you a proposed solution.
I would be interested if there was a reply to Luber's request. Luber can e-mail me direct to hansend@asme.org (David Hansen).
I would also like information on wireless data colection systems. E-mail me direct jack.burn@celaneseacetate.com
Contact Zeefax Inc. Condition Monitoring Systems at 1-215-230-5500 for wireless systems information
I hope giving this information is OK
What is the max. distance ? Are the TX or RX moving or are they both static? How fast the response have to be ? Could
you use infrared ? Ultrasonics ?
Are the TX and Rx in one building ? could you use the line ?
How much error-rate can you afford ?
If you want help, give spec's !!!!
<nbucska@pcperipherals.com>
