NickParker
- Sep 1, 2017
- 435
I watched a webinar in YouTube, which says
The maximum single load that can be connected to low-voltage switchgear is 1/3 the incoming breaker's amps; for example, if the incoming breaker is 4000A, the maximum single load that can be attached is 4000/3=1333A. If one load is more than 1333A, another MCC or switchboard must be used to connect it (which is better in his opinion)
I wonder, What is the justification behind this? Is it because of coordination between the Incoming breaker and that particular largest outgoing feeder?
