Sinus measures in IDEAS 9.1
heitor
50
Hello.
I am using Ideas Test to study the dynamical behavior of a rotating machine.
I want to take the measures at several spin speeds. I can do it by using the "Standard Measurements", but for each spin speed I have to store the measurements in a data file. That is, I put the machine at 1000 RPM, then I press the "Acquire" button, I give a file name and again I press "Aquire" at the preview screen. After the acquisition, Ideas goes back to the main screen. For 1100 RPM, I repeat all the procedure. So, for each speed I have one data file.
Can I do all the measurements and store then in only one data file?
Thank you!
