ballpeen
Industrial
- Oct 7, 2005
- 20
Hello all. This is my first post so bear with me. Recently I have been promoted to a lead person job and fill in when my Supervisor is out. This past week one of the shop personnel went out to install a newly rewound motor and could not get it to work right. He said it sounded like it was single-phasing.
We ended up taking the original motor back to the shop and repairing the damaged shaft, which was the reason why it was taken out in the first place, and fixing that.
Meanwhile I had them bring the motor in question back to the shop for some experimenting. When I called the motor repair facility, they claimed the motor should be fine, and to check with my Supervisor to see how to hook it up. That was not possible at that time.
The shop guys were able to get the motor to run by shorting 3 leads together and using the other 3 as the phase leads. But have been unsuccessful in getting a 2 speed effect.One of them mentioned something about a "consequential pole" but was unsure if this was the case.
My main forte' is machining and welding, but I have taken alot of electrical courses and from what I see it is a matter of utilizing a different set of poles to get the desired speeds and it shows that in the original prints. I know the fewer poles, the faster the motor will run, trying to play catch up with the rotation of the fields.
Now when we received this motor it had markings 1 thru 6 on the wires, but no indication as to how they are connected.
Its either this motor will only have 1 speed or it hasn't been rewound right for the intended use as required by the manufacturer.
Does anyone here know if it is possible to derive 2 speeds from this motor?? Thanx.
