sizing psv for expander
Idontknowit
Chemical
Feb 12, 2008
23
Guys,
I have request from the client to perform PSV for Expander which is simply piece of pipe larger diameter downstream of the high pressure vessel filled with gas.
My question is should I make psv sizing calculation for this expander with size 1,5mm x 25mm as I have already sized the PSV for upstream high pressure vessel?
any thoughts/comments very much aprreciated.
It's difficult to say what physical configuration you should size it for without knowing what the relieving conditions are.
