Sketch changed colors all of a sudden.
qreason
Industrial
BE
So i was drawing a sketch and all of a sudden the colours changed from default green to blue, which makes it impossible to differentiate all the lines in the background from the sketch lines...
Been looking for a solution but haven't found one yet...
Thanks in advance!
 https://files.engineering.com/getfile.aspx?folder=6aa465e6-7cb9-4a8c-95db-548ad03be5e5&file=prrf.JPG
This is a slightly complex question. ( it's not a matter of changing the CDF.)
All this is originally controlled from the "Customer defaults" and then saved to your template parts.
Preferences- Object you can set the default colors for objects such as lines, arcs, splines etc. But:
There is a setting ( no sketch active when doing this) Preferences - Sketch... - Part settings, where you can set colors for the different aspects of "Sketch / sketching":
"draw curves in the color xxx, Automatic dimensions color yyy" etc but also "Inactive sketch color" .
i.e activate the sketch and the curves change colors accordingly to the constraint condition.
this will override the Preferences -Object colors.
When a sketch is active, there is a dialog "Task- Sketch settings" and a button "Display Object color" which ...will set the display according to Preferences Object ...
Tomas
