My one-way slab is exposed as shown below. What do you recommend for the connection to the capping beam for the consideration of temperature. I am thinking not having any connection so the slab will be able to rotate freely? Any issue with this?
So that slab is cast monolithically with the supporting beam? The solid line fooled me.
So that is a contiguous or secant pile wall. Does the wall rely on the slab for lateral support? If so, it would need to be tied. If not, let it slide, in which case, some type of bond breaker would be helpful.
Yes to the first question and no to the later one
Secant pile wall is not needed for lateral. But, what if I tie the slab to the capping beam regardless? Is it a concern for temperature?
Do you mean making the capping beam the same level as the slab and have shear connection instead of bearing?
(Sorry I just saw you attached a picture)
I did the similar connection for slab to the LHS beam.
But it restrains the slab and thus cause problem for temperature if I have this connection for both ends or am I overthinking?
So if the piles are not contiguous, what retains the soil? Restraint is always a concern, more for drying shrinkage than for temperature. So if you don't need the slab to brace the top of the piles, as I said, I would let it slip.
