I am wondering if any of you has conducted slope stability analysis with ABAQUS.
Finite element is powerfull tool for observing Slope stability behavior with time. The Maximum contour of Mises Stress can be considered as mark of the slip surface location while FOS is computed by a criterion established by the analyst.
Ideally the slope is a geo-system subject only to gravity force. However, if one uses Geostatic step during which the gravity load must be applied then one will get zero stress case.
Your detailed comment is very valuable in this regard.
