RareBugTX
- Aug 31, 2004
- 214
Hi all:
We are designing a two story home where the sloped roof (10:12) is going to be reinforced concrete slab (one way for analysis).
I would like to hear if someone has dealt with this situation before, I am thinking in considering the ridge as a rigid support as it is going to be nearly perpendicular to the slab on the other side (gable roof).
Also there is going to be outward thrust at the CMU wall support on the other side. I am thinking that the beam would be subject to the lateral force as well as the gravity component.
Your thoughts are welcome.
