skylite
- Oct 6, 2015
- 21
2 pcs of 20 feet Wide Flange w8x21 will be connected at a slight sloped at middle without any central beam ridge or support. They will make up rafters supporting light roofing shed . The connections at the middle is shown in the above image. Can anyone recommend what kind of horizontal stiffener to make it stable? It will be located in a seismic zone so the connections need to be competent. Or for the span and sizes.. won't you recommend it at all?
