Small Engine 6.5 Tilting 5
paskee
Agricultural
Nov 8, 2012
18
Hi Guys.. I need advice.
I have purchase a Briggs and Stratton Vanguard 6.5HP Horizontal Engine (w/ splash lubrication system / motorsports rod dipper design).. I want to tilt it to power a small boat's propeller... the manufacturer does not recommend it ( but I've seen similar small engines being tilted in operation...
what angle from horizontal do you think I can get away with w/o causing engine failure/long term maintenance issues?
It will be operated daily, 10-12 hrs
So far the best suggestions are a vertical shaft engine cobbled to an outboard leg like BrianGar did, however few have Brians talent, skill and resources to pull such a project off.
Pat
See FAQ731-376 for tips on use of eng-tips by professional engineers &
for site rules
I also like the option of throwing the whole lot in the lake if it goes on fire. That, and the fact that my nets dont wind around a 4ft driveshaft while at the same time getting burnt eyes from exhaust smoke,
Brian,
Got this just now:
All of our engines are safe to operate at no more than a 15 degree angle of operation.
Mike, Briggs & Stratton Answer Center
Last week, person I talked to at Briggs, just said "we do not recommend it" . I pursued and wrote to their technical support center, knowing that the Asian do it (tilt their engines).. I received the above reply , and I like to share it with you guys.
BUT .... I'll test the engine I bought with a universal joint to get to my desired 22 degrees tilt. As some of you suggested , I will place a thrust bearing between the engine and propeller ... I think this is safe, inexpensive and prudent. If everything test well (in a month or two)... I will start producing about 100+ units (that is why the economics !) .. its for our farm operations ... we raise fish on a 200 acre farm.
Thank you to those who contributed... I like these forums, their great! I wish I can return the favor.. I will if anybody likes to consult on "water engineering" in particular, agriculture in general.
Again, thanks..
Mike,
The link you sent.. "the Hog Mud" ... was great... it gave me the solution on how to "structuraly implement / put together" the inclined pump I am designing... I saw that they included a universal joint --- it will solve 2 probles: gives me the extra 7 deg (15 vs 22) I want and facilitate ease of alignment in fabrication and field repair !!!
Thanks, P
I did not see a thrust bearing identified in the mud hog image. Maybe one of the bronzed bushing has thrust flange(s), but my hunch is a greased flange bearing is not going to like 3600 rpm, which is likely where the engine's rated HP is. If there is no T-brg on the main shaft The U-joint would pass the thrust to the engine, just as when the axles are used in many Corvette rear suspension as the upper link.
