Smooth Curve Help
BrittToolEngineer
Aerospace
Aug 4, 2016
239
Greetings:
I have an arc that comes close to a line, if extended, they both miss one another. What is a good option to create a smooth curve that best fits between the two creating a smooth transition between both points?
Brent
Have you looked at using a Bridge Curve?
BTW, a picture would help.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
Could the circular blend curve be of help ?
It will create a spline between two existing objects , the spline looks like a circle in a given direction.
Tomas
A Bridge Curve should give you the 'smoothest' transition, but the Circular Blend might work as well. It's worth a try either way.
Irvine, CA
Siemens PLM:
UG/NX Museum:
