Snapping to 25%, 33%, ##% of a line's length
Cradders
Materials
Mar 26, 2008
19
Hello, another question!
Is it possible (through snap points or expressions) to draw a line that is a specified percentage of another line's length? I don't want to reference a specific line, but say, the line that is currently selected. I am making a UDF that is based on the selection of a line and want to generate a line that is a certain percentage of that line.
Thanks,
James
if you are sure you will deal with LINES only, one thing that comes into my mind is to create a first point entity at 0% length (t=0), then a second one at xx% (t=0.xx), then create a line between these two points.
Certainly in the myriad of UG tools there is something better than what I described...
If you know how long the line is then by using the reference method and distance along a line sure, just type the calculation under the length expression as you go. It wouldn't be something that you want to do frequently but I expect the need would not be very common.
Best regards
Hudson
Thanks guys, I'll have a look at the t=0.xx method.
Cheers!
Expressions are the way to go.
Believe it if you need it or leave it if you dare. - [small]Robert Hunter[/small]
