During a retrofit I have a new solenoid valve (automotive 12V)that has a coil resistance value of 12.2 ohms. The solenoid valve is actuated by the ECU. The original solenoid valve for this ECU had a resistance value of 10.3 ohms. It doesn't appear the new valves are funtioning. Installing the earlier valve is not practicle. Is the resistance value difference enough that the ECU can not operate the new valve? Is there a way of making the new higher resistance valve work? Thanks!
