I know these are some really basic questions but I appreciate your help since I started using SW less than a month ago. I am using version 2008 SP0.0.
1- How do I resize a part proportionally and unproportionally? i.e. change length but not width or vice versa?
2- How do I translate/rotate a part? I know this can be done using the coordinate system but I cannot figure out how to do it for the whole part.
3- Is it possible to subtract a 3D object from another? I could successfully draw a screw but now I need to draw a block with a hole that exactly matches the screw and its threads. Is it possible to subtract the screw from a block or so? some software can do so by what is so called "Boolean operations". Is this possible in SW?
Thanks so much
Thanks so much
