Some questions about macro programing
AtomicNico
Nuclear
FR
Hello everybody,
As you can see I'm new to this forum and I browsed it searching for my answers and unfortunately I didn't find it, so here I am!
-Can you change of workbench while you're executing a macro through the "CATIA.StartWorkbench ("name of workbench")?
Like I want to extract some datas in analysis workbench then change of workbench to extract mass, all of that in 1 macro
- What is the differences between Product and ArrangementProduct when you declare something? And sometimes I can see
objArrRun As Run​
objArrRuns As Run[highlight #EF2929]s[/highlight]​
Is there a difference? Putting an S won't make a difference?
- For the function .Search, I saw some ways to write it and I wanted to the differences and the conditions of writing one or the other:
oSel.Search "'Assembly Design'.Part, all"​
or
oSel.Search "(CATLndSearch.Part),all"​
Does the CAT***Search is depending on the workbench you're currently working in?
- I saw several topics about finding the mass and the inertia through a macro which used the 2 sames ways as I saw on other sites, but when I tried it on my computer, none of them worked, so, in which cases do you use these 2 ways:
Dim TheSPAWorkbench As Workbench
Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench(“SPAWorkbench“)
Dim productInertia As Inertia
Set productInertia = TheSPAWorkbench.Inertia.Add(Product)​
and
prdProduct As Part
On Error Resume Next
Set productInertia = prdProduct.GetTechnologicalObject(“Inertia”)​
FYI, I'm working on a computer where the documentation of CATIA was erased
Sorry if bad english, not my first language.
Best regards
FYI, for the extraction of the material I got this
Code:
Dim objProductMat 'As Product
  Dim intNbParts As Integer
  Dim k As Integer
  intNbParts = objGCATIASelection1.Count
 For k = 1 To intNbParts
    Set objProduct = Nothing
    Set objProductMat = objGCATIASelection1.Item(k)
    Err.Clear
    Dim objInertia As Inertia
    Set objInertia = objProduct.GetTechnologicalObject("Inertia")
    Dim getMass As String
    getMass = objInertia.Mass
    Dim Mat As Material
    Dim oManager As MaterialManager
    Set oManager = objProductMat.GetItem("CATMatManagerVBExt")
    oManager.GetMaterialOnPart objProductMat,Mat
    matName = Mat.Name
    'MsgBox matName
    Dim Coordinates(2)
    objInertia.GetCOGPosition Coordinates
Everything works fine except the material
plz remove on error resume next
Eric N.
Ok I did it, there are no On Error Resume Next in the loop but I still can't get material, in fact, it gives me an error: "Method GetItem failed" line "Set oManager = objProductMat.GetItem("CATMatManagerVBExt")"
Is it possible, somehow, I don't have CATManagerVBExt?
ok i was expecting this line to fail...
can you tell us what type is objProductMat ? is it a product? should it be a part ?
Eric N.
I declared objProductMat as a Part at first, then as a Product, and finally I commented the "As ****", just letting "Dim objProductMat" and there were no differences at all
if you removed all your on error resume next it should make a difference.
it is bad VBA programming to use on error resume next everywhere for no good reason. I use this only to do missing VBA stuff like try / catch and always put a on error goto 0 to close the effect.
next question is what do you pass on objProductMat from your selection? a product or a part?
Eric N.
objProductMat comes from a selection: Set objProductMat = objGCATIASelection1.Item(k)
Each component of the assembly here is a product
Though the selection is
Code:
If objGCATIASelection1.Count = 0 Then
    objGCATIASelection1.Search "(CATLndSearch.Product),all"
  End If
ok so you give a product to oManager.GetMaterialOnPart ?
and you expect it to work?
[bugeyed]
Eric N.
Oh yes indeed, I noticed it on my code before so I changed it but I didn't change it here on the forum.
So actually the line is oManager.GetMaterialOnProduct objProductMat,Mat, sorry for this mistake
no problem... glad you fixed your code.
is it working now?
Eric N.
No, since I removed the On Error Resume Next, I still get "the Method GetItem failed"
For information, I tried to apply material on the body of the part, on the part and on the product and none of that worked
may be you need to type your variable when you Dim it
Eric N.
Which variable? I thought everything was declared [ponder]
dim objProductMat as Part
Eric N.
Humm, it's still not working.
Is there a special command to activate GetItem("CATMatManagerVBExt") before?
your code with the 4 corrections explain bellow your post works for me
Eric N.
Code:
  Dim objProduct As Product
  Dim objProductMat As Part
  Dim k As Integer
    Set objProductMat = Nothing
    Set objProduct = objGCATIASelection1.Item(k).Value
    Err.Clear
    Dim partName As String
    partName = objProduct.Name
    Dim Mat As Material
    Set oManager = objProductMat.Item(k).GetItem("CATMatManagerVBExt")
    matName = Mat.Name
    'MsgBox matName
Here is my loop which is working except for the material, and I don't get the error about GetItem anymore
(Since I got an Assembly with >200 elements on it, I commented MsgBox)
BTW, I didn't say it earlier, but thanks for your help :)
are you sure Set objProductMat = objGCATIASelection1.Item(k) is a part? I have the feeling it is a selectedElement
Eric N.
Humm, my selection is made this way:
Code:
  Set objGCATIADocument0 = CATIA.ActiveDocument
  Set objGCATIASelection1 = objGCATIADocument0.Selection
  Set objGCATIAProduct1 = objGCATIADocument0.Product
  End If
Maybe I should use objCATIAProduct1 instead of objGCATIASelection1.Item(k)?
And I realise objGCATIAProduct1 is never used, so if not useful, I should erase it
so you have Product in your selection and you passing a product to oManager.GetMaterialOnPart
Eric N.
