some questions about steel fabrications
ELSARWAN
41
Dear experts,
hi every one ,i don't have much experience in production of steel members ,so i have some questions for experts here,
first,
what is the max thickness that can be accepted to make cold formed steel members like (C -channels .Z channels)
2-for hollow square sections with small thickness like 40x40x1.5 mm it's hot rolled or cold formed
3-can i apply weld size = 2 mm between steel members
thanks alot
Would be good to know which area of the world are you working ??
In some areas of the world you can get whatever you want :)
best regards
Klaus
ELSARWAN...
1) Contact you local fabricator or supplier. The fabricator that will be doing the fabricating for you will tell you what they are capable of - or - the supplier that you or the contractor would be purchasing from will tell you what is available.
2) HSS (hollow) sections are typically hot rolled sheet / plate, cold-formed to shape or section, and then shop welded, seam welded to close.
3) 2mm weld is extremely small. The smallest I've ever specified would be 4-5 mm. The weld specification will depend on your application.
Contact your local fabricator or supplier. They will be the experts to these questions.
thanks a lot guys for your helpful replies
i am in ksa
