Sorting string from an array
Camille1
Aerospace
Mar 25, 2005
12
I have a list of strings and I would like collect from that list only one time if the strings the same for example if an array("A", "B", "C", "A", "B", "B")
and I would like to collect ("A", "B", "C"). How do I do that. Thanks in advance
One way would be to put the array into a collection, since you cannot have duplicate data in a collection, only those strings not equal would be in the collection.
Regg
Hi Regg,
I am kind of new to VB, I tried to collect like you suggested, can you give me sample code.
Sub Sorting()
Dim ListString
Dim CollList As New Collection
ListString = Array("A", "B", "B", "A", "C")
i = 0
Do
CollList.Add ListString(i)
If i = UBound(ListString) Then Exit Do
i = i + 1
Loop
Debug.Print CollList.count
End Sub
I use a dictionary to do this
Sub GetUniqueEntries()
'note add a reference to Microsoft Scripting runtime to be able to use dictionary objects
Dim ListString, i As Integer
Dim DicList As New Dictionary
For i = 0 To UBound(ListString)
If DicList.Exists(ListString(i)) Then
Else
DicList.Add ListString(i), ""
End If
i = i + 1
Next
For i = 0 To DicList.Count - 1
Debug.Print DicList.Keys(i)
Next
End Sub
Camille1,
Sorry for taking so long to answer your reply.
What I meant was that collections do not allow duplicate keys. Try this code:
Code:
Sub Sorting()
    [COLOR=green]'declare variables[/color]
    Dim ListString As Variant
    Dim Item As Variant
    [COLOR=green]'create collection[/color]
    [COLOR=green]'create test array[/color]
    [COLOR=green]'set error routine to skip duplicate key[/color]
    On Error Resume Next
    [COLOR=green]'loop through test array[/color]
    For Each Item In ListString
        [COLOR=green]'add item to collect using item as both item and key[/color]
        [COLOR=green]'collections do not allow duplicate keys and raises error 457[/color]
        [COLOR=green]'On Error Resume Next lets program continue on with stopping[/color]
        CollList.Add Item, Item
    Next
    [COLOR=green]'turn off error handling[/color]
    On Error GoTo 0
    [COLOR=green]'display number of collection items in immediate window[/color]
    Debug.Print CollList.Count
End Sub
Regg
I learned new things from this. Thanks to all of you
Camille1,
Just out of curiosity, how did you solve your problem?
Regg
