1
- #1
allimuthug
I have pile cap having both the cases given below
Case-A
The pile cap supporting column with base plate and anchor bolt .
Case-B
The columns are removed along with the base plate and anchor bolt , Crane would be moving over the pile cap.
To satisfy the above cases the ANCHOR BOLT must be of an removable type, as well as the above two case occurs continuously , means after some time columns are again supported and anchor bolt is again fitted in the same location .
Please suggest what type of anchor bolt should i use in this case , Please also note that the above two cases are occurring in corrosive environment. No Hiti Bolts are Acceptable as well for above case.
Please find the two cases attached with the link below
Case-A
Case-B
