WADMW
- Mar 26, 2016
- 36
I'm hoping to combine the power from two cycling machines to generate a single output.
What do you think is the best way to combine two shafts, in line (coaxial) or parallel, rotating at two different speeds to get a single output? Will a power split device do the work for you, or is there any other mechanism to achieve this?
