crunchie12268
I am using a SKF 22207E spherical bearing with a SKF N 207 ECP in a cantilever arrangement. With my setup I am placing approximately 4100 lbf of radial load on the 22207E bearing, when I am using the calculator on SKFs website I get a rolling frictional moment of 2.34lbf. Now I have a moment arm on the shaft that is running through these bearings of 1.2 in so I get a force of 1.95 lbf required to overcome the frictional moment (my customer calls this "tension"). Here is my problem... the specification is calling for a min "tension" of 0.4 lbf and I cannot change anything but the bearings, it has to be the same dimensionally too. I can't change the operational parameters such as the radial load either. I am beginning to think the 0.4lbf is not attainable.. anyone have any suggestions?
