Spiral as a Sweep Path? 1
MadMango
6,992
Any work arounds for this? I need to model a coiled cable.
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read faq731-376 to make the best use of Eng-Tips Forums?
What sort of problem are you having? I found that if you create the spiral based on a origin-centered sketch, you can then create an axis perpendicular to the spiral. Then create a plane through the axis and the end point of the spiral. Use this plane for the section sketch and the sweep should work. This works in SW2004.
Kristin Jugenheimer
I take it that you need something other than an involute as the spiral only allows...
Why dont you try using the insert/curve by xyz points and create your "spiral" that way?
Would that work?
Jon
jgbena@yahoo.com
What's seems to be your Problem there MadMango?
It works fine here? You can't have the Sketch profile touching itself or it will fail. I just keep a very small gap in between each coil and it works fine.
Scott Baugh, CSWP [borg2]
faq731-376
Bah, must have just been a Friday the 13th thing. [witch]
It's working now. Thanks all. [cheers]
Ray Reynolds
The following has been true for helixes up to SW 2003. This may be valid for spirals.
After using a helix for a sweep path in a spring model, the endpoints of the helix are unavailable for future feature reference (spring arms, in this case). The workaround is to make the helix, then copy the helix in a 3D sketch using Convert Entities, and used the sketched copy as the sweep path.
[bat]"Great ideas need landing gear as well as wings."--C. D. Jackson [bat]
Thanks Tick, that was my problem.
I was selecting additonal sketch elements along with the sprial, and didn't notice that my sweep profile wasn't following the entire sweep path (only the additional sketches I added). I'll keep this Convert Entities trick in my back pocket for future use.
Ray Reynolds
