  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Spiral Fracture of Hex shaft 1
ewalk
Agricultural
Jun 22, 2007
14
0
0
I have a 30mm hex shaft turning at 650 rpm. The torque varies from about 339 ft-lbs to 1357 ft-lbs. Normal running torque should be about 450.
The shaft fails at the lowest torque. The latest failure is continuous spiral with fractures about 1/4 inch apart.
The material is DIN 42CrMo4 or AISI (41400).
I do not believe there is any heat treat on the shaft as I can easily cut it with the bandsaw.
