bugbus
- Aug 14, 2018
- 533
General question regarding proper splicing detail of bundled bars in piles and columns:
AS3600 and AS5100.5 (and presumably all other relevant codes) require the individual bar splices in a bundle to be staggered by no less than the lap length. In our design drawings, we typically show this as a specific detail, usually at most for 2 bars in a bundle (I have not had to design bundles of 3 or 4 bars, which can usually be designed around and are in any case not allowed for seismic reasons in most cases by AS5100.5).
However, for a 2-bar bundle lap splice, on two occasions (despite our drawings) I have seen a contractor simply provide a double-length lap splice for both bars in the bundle and terminate both bars at the same location (presumably to simplify the reinforcement).
Is there any harm in simply providing this double-length lap splice for both bars in the bundle and cutting off both bars at the same location? I am in two minds about this. On one hand, this detail basically takes the preferred staggered lap splice arrangement and 'adds a bit more length' to two of the bars. It could be argued that this detail still satisfies the requirement that the lap splices are staggered. I am generally of the opinion that adding additional reinforcement will not reduce the strength of the member.
On the other hand, the staggered lap splice arrangement would basically 'force' the two splices to act at two separate locations and reduce the possibility for requiring too much (what I would call) 'bond demand' at a single location, which might encourage splitting/cracking.
Any thoughts?
Any thoughts?
