  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Splines Behind the Part in a Drawing
Jashe
Automotive
Jun 19, 2013
204
I'm trying to create splines in a view in a drawing (NX 2007) and when I exit the sketch and update the drawing they disappear. After playing around and erasing the part in that view using View Dependent Edit, I found the splines. They are behind the part in the view. Didn't even think that was a thing. How do I get those splines in front of the part within the view?
I assume it has to do with Clip Planes.
I am not at work now, so I will try to get back to you later with a solution.
Jerry J.
UGV5-NX1899
I hope this is the issue.
RMC on drawing view and go to Settings.
Jerry J.
UGV5-NX1899
I am not aware of a simple solution to this issue.
The strange thing is that when creating a sketch in a drawing view, there is no way of defining where in "depth" that sketch will be created.
Report this as an issue to Siemens.
Tomas
The more you know about a subject, the more you know how little you know about that subject.
