Split Line Single Side 1
battlehands
19
I should be obtaining a total of two faces after the split line feature with "Single Side" is completed on the attached part. However, the resulting feature has three faces. Please advise.
TIA - battle
That's probably because the sphere is a single face. If you split a hemisphere, you achieve what you are expecting.
If you place the ellipse sketch on the Top Plane, you will also get what you want.
